How did you turn off the rescan interval?where is the cfg-file located.
The Beosound Moment Beta 2.x thread
You can do the same from the Twonky UI by setting the Rescan Interval to 0, and it should be the way to configure it to avoid clashes with the Moment own scan that cannot be configured.
I think it's time for B&O to consider a "control screen" where users could perform basic controls from the JB without having to remove the socket cover, e.g.
DLNA sync (assuming we can also set it manual v.s automatic in the configuration)
Deezer sync (assuming we can also set it manual v.s. automatic in the configuration)
Tone
Balance
Light
Mute
Don't you think?
can you tell me the URL you can watch the activity at the BS Moment?
Fully agree Mbolo
The URL is http://[soundheart-ip]:8080/BeoNotify/Notifications
I have Moment connected to BV1 and speakers connected to the BV1. When I switch from i.e. radi to tv, the JB shows the TV program. When I shut down the tv, The JB stays on, displaying the last TV station. I have to press manually the center of the ring of the JB to get it in standby.
Is this a bug?
Is this a bug?
Yes, this is bug that Lyle is aware of, the same happens if you have the Moment in std.by, and just tap the screen without starting play, it turns on the screen, but dosn't turn off unless you press std.by on a remote, and sometimes you first need to start playing music, and the press std.by on remote or wheel.
/Jacob
... Lyle is aware of...
/Jacob
Do you still get feedbacks to your reports/ mails to Lyle? Since weeks it is awfully quiet. I asked arround – No responses from B&O. Is he still there or is he on leave/vacation? Hope the later – since the development on the Moment improved very well.
Beroli
Latest answer was May 20 :-(
