Agree it would be a good feature/ characteristic, going to the now playing screen
I would say 30 seconds or so sounds about right, not less...
2 People wanting it, one says 60 seconds, the other 30... I vote for a settings page ;)
/Jacob
/Jacob
Set a default value (of 30 sec) and make a 'user setting/configuration possibility' for those, who want to tweak the setup.
I'd say first iteration to have now playing with a 30 or 60 second time. Next iteration a user configurable option (sorry was in Agile thinking mode) 😁
A "user interface" would be a great idea, to personalize the moment.
I would add the optional possibility what kind of songs are shown in the collection menu. In my eyes the collection menu is quite confusing or inflated if you add big playlists e.g. 50s, 60s, 70s,.... or if you add "one hit wonders" to your favourite songs.
Just got the moment a week ago - The "now playing" way of working had me miffed (POLA violation if you ask me) - think there is a couple of options - Once a selection is done - e.g. within a short interval "now playing" should be the options; Need a short delay to allow me to change my mind; One on the "now playing" I would expect it to return to where it came from
Hi all,
Since the new official release of the 2..0.66 software it works very smooth. One thing I noticed is that when I use search function (i.e. artist), after selecting an album I cannot see the numbers but the Moment starts to play the whole album.
I would like it to work with more detail so I can find an actual number from an actual album and select it to play from the search function.
for instance: type madonna under artist, then select album from the findings, select album madonna and have an overview of all numbers and then select song Holiday
Is this feature up for new updates? Maybe it is in already but I do not know how to operate 😉
Thanks for your thoughts
No, this is how it works, and I agree with you, there should be someway of "drilling down" to see the numbers of a searched album. But.. if you know what song you are searching for, then just select "songs" instead of albums.
The only way of doing it now, is to "heart" the album, and find in under your collection to see songs. If you then don't like the album, do a search for it again, and the search result will show you the albums you have hearted as the first results in the search result.
But... I don't find this interface totally intuitive either, I guess it is difficult to make it simple yet complex at the same time.
/Jacob
Switching to the playback screen is a great idea. Count me in! (having a time setting is the way to go :-) )
