The Beosound Moment Beta 2.x thread
Lyle Clarke wrote:
What is being considered is 'Spotify Connect' where the whole experience is controlled by the Spotify app on your mobile device. Moment is simply a 'speaker'. For the MoodWheel functionality Deezer is required.
That would ok so!
And it would widen the acceptance of the BS Moment, I am sure.
Of course Deezer wil remain fundamental.
After all this is - and should stay - a Mood and PatternPlay device, and for now Deezer is the only way to integrate a music service with it and in a multiroom/NL setup.
Lyle Clarke wrote:
......Moment is simply a 'speaker'.
Would that work, if the 'speaker' is integrated with a NL-BV - that is, if the tv is the 'speaker'?
To what I understand, that will work.
andy_js wrote:
+1 for Apple Music.  I use iTunes to manage my library which gets synced automatically to the cloud.  If the Moment supported Apple Music I wouldn't need to have Twonky running on my Mac, or even have it switched on.  Bonus points for being able to have Apple Music replace Deezer too.
+1 also, would be nice for the same reasons 🤒
PeterBOBP wrote:
Here is what I found so far:
  • “null”  and numbers shown with radio stations pictures / tiles (i guess that is what you are referring to)
  • quite of lot of Deezer genre pictures not shown in the Radio section
  • If you “like” a song (swiping) on the Moodwheel display, you do not get the message “I like” (as you get in the now playing screen). This message used to be there but with the 2.x release has disappeared.
release 2.1.89 etc
null issue: resolved
"like" not shown in mood wheel screen: resolved
numbers / no genre pictures in Radio action: not resolved.
Lyle Clarke wrote:
You have not missed anything. This gets fixed in an upcoming release.
@Lyle - not sure if this is connected, but yesterday the panel just went black - not able to charge it. Not on the beta s/w. Any recommendations?
Roger
Hi Roger,
I have had the same problem. My Jukebox went black and won't start again. I have given it to my dealer and the dealer send it to B&O. Today my dealer called me, that I have to bring in the Soundheard too. :-( They have to send it to B&O too. Seems to be a bigger problem.
Mirco
Thanks for sharing Mirco - there is some comfort in the fact that I´m not alone, but this doesn´t sound too promising. I sent my serial no to Lyle so his team can have a closer look, but I´m afraid that your post shows what to expect.
Roger
I encounter some strange behaviour of the Moment and the Horizon. Not sure what causes the problem, so I give it a try in this threat also.
When listening through the Moment and the connected TV speakers of the Horizon, after approx. 2 hours the stand-by mode is selected. Both Moment and TV go in stand by. Settings in Moment are selected for auto power off after 24h, the Horizon does not have a clear setting for auto power off for NL sources. The regular timer is set for power off after 4h.
Hope this will be amended in near future update. Thanks B&O
3 weeks ago I got the Jukebox replaced.
Then I got Beta 2.1, and I had problems with Beomusic could not work with my Moment.
Then last week there was an update to the Beta, and suddently everything worked, for 2 days, then I had problems again.
Then yesterday I desided to try a reboot, but then I could not connect between Jokebox and Heartbeat.
I tried then to use LAN cable instead of WiFi to the Heartbeat unit, then everything works again.
My question, is it then the Jukebox or the Heartbeat that has a problem?
If I listen to TunIn and disconnect cable, I loose connection to Jukebox, but I just get a short fall out in the music and them the radio continues.
Input appriciated :-)
