The Beosound Moment Beta 2.x thread
No.. Nas is working fine for any other stuff. Using the dlna server with kodi for example works like a charm. I have 2 ethernet port on it and I use bonding to make sure I have enough bandwidth coming from the nas whatever happens (2gb)...
Really don't understand what happens. Since I deserted it even doesn't get stuck @1% it directly stops.
Are the two interfaces aggregated and what ethernet switch are you using? I would test with one Ethernet interface active only.
Thanks ! 🤒
B&O seems to be on the right track with the new software. 😳
Hi all
After having played with the Moment and the latest beta sw... How do I add an album I have found via the search function ? It is a Deezer album I would like to add so I can find it later ?
There are some things that I find not very intuitive about the search, and I don't know if it is even possible ? Do I need to log in to Deezer to do this ?
/Jacob
If you heart it (press on the heart on the right of the album), it will be added to you Deezer collection, but for that as for many other Deezer related actions, you need a premium account with Deezer
Already tried it, but it didn't do anything, the account is my dealers Premium+ account, maybe there is a delay before the collection is updated ?
I will try with patience :)
/Jacob
I just tested it, heart an album on the JukeBox then refreshed my albums in the Deezer IOS app, in less than 15s the album was available in my collection as well as behind the artists tile in the JukeBox
Ok, so you need to refresh via the IOS app first, for it to appear in collection on Moment ? Or does it maybe require the Moment to refresh the collection via settings ?
I would just like to heart and then without doing stuff, see the album under "collection"
Will play a bit more with it :)
/Jacob
This is the way it works, I previously went to Deezer to check, not to trigger.
To confirm, I just unliked the album I previously liked, waited 5s, went to Collection and the album is no longer present.
What I have not tested is to heart an album of an artist that is not already present in my collection, this may take more time, I'll try and let you know
done ..... it just took the time to leave the search screen, where I hearted the album, to reach the collection screen where the new artist tile had been added and the hearted album behind.
The good thing in this test is that it helped me to understand a strange behavior I observed: for a reason I ignored up to now, DLNA full scan started without any change at the DLNA server level. I think now that material changes on the Deezer side, like adding a new artist (or album) to a Deezer personal collection triggers a DLNA full scan, inconsistent IMO but real.
