Is there a convenient tool for creating m3u lists on Mac?
For those if you using iTunes to manage your music File>Library>Export Playlist... and save as an m3u file.
https://www.youtube.com/watch?v=b4HoT7_mHZU
not sure if you have seen this....someone playing with the newer software.......not sure how radically different it is, other owners will have to opine.......thinking of one myself, even though i dont use Deezer.....similar use case to you.....NAS collection, plus some TuneIn, hoping to Bluetooth in Tidal from my iPhone...though not sure how easy / well that last bit will work.........
Yep, that is one of the earlier versions of the Beta. Its not radically different in terms of GUI, other than the clever search function covering Deezer and DLNA simultaneously. Using Bluetooth is simple. Once you device is paired, and you start playing from your device the Moment switch to that "source".
Simple I would say.
It's true, the GUI is not radically different, but thats ok for me. I don't think that the user experience would vastly improve just from a total redesign, most of the time the small ideas and improvements are by far more important. A totally new interface would just bring back some basic mistakes.
I'm still not happy with the mood wheel. The music selection from the middle and outer ring misses to many time my taste. The inner ring works perfect for me. But i miss a little bit the MOTS from the Beosound 5.
What i like is the information you now get when you take the lid off. Really nice. The only thing a been missing in the Notifications section: You're able to see the time, but you don't see the date, or did I miss something.
Hi Hiort.
Can you confirm me if you are using your synology n'as with the standard multimedia app or a 3rd party one ? Harvesting is stuck at 1% since 3 days now on my side... (I upgraded to the beta on Sunday night).
Thank you for your feedback.
Christophe
I found a link with the explanation, new features of the new software:
Normal 0 21 false false false NL X-NONE X-NONE link
Hi Hiort.
Christophe
Hi Christophe!
I´m using the built in media server. I´m using DMA menu style "Advanced".
Other than that I use the default settings.
I would do a factory reset after the upgrade, if you have problems.
Thanks for charing. A very good walkthrough of most of the improvements.
Thanks for that link - great!
Hi Hiort.
Christophe
I have responded but the response is in moderation :) But yes, I use the built in Media Server. Suggest you do a factory reset.
Presented by Mr Clarke himself 😁A very good walkthrough of most of the improvements.
