The Beosound Moment Beta 2.x thread
Carolpa wrote:
Chris wrote:
I don't see the relevance of adding a date, I would find it a lot more interesting in making it possible to send the logs file also to your own email address.
if a time is displayed one should also display the date. Other wise it is confusing or at least it doesn't give any additional information.
If things happening I want to find the relations between effects and causes. Than a date is as essential as a time (as normal in logging of events).
Can anybody explain why this reply had to be moderated?
thanks
Can anybody explain why my answer, see above on Sat, Feb 4 2017 5:33 PM, had to be moderated?
I quoted the same post and it had to be moderated to.
thanks in advance
All my remarks seem te be bound for moderation? it started with my reply on Sat, Feb 4 2017 5:33 PM
Can anybody explain what I doing wrong?
thanks in advance
mbolo01 wrote:
Carolpa wrote:
How do I empty the play queue on the SH?
Through the BeoMusic app only to my knowledge
Correct, this is the only way I know to do it. But how on the SH...........? that's the question!
MircoHH wrote:
does anybody know, if B&O will include the Deezer Flow function? I like it very much, but I can't use it with my moment.
Mirco
In my opinion, the MoodWheel feature is more or less comparable, by adding owned music tracks in the middle ring, it would even be closer.
That said, a quick win would be to add Google Cast support to the Moment
I'm pretty sure you will find all relevant information on the logs... If you could approach them!
How do you add songs to the middle ring? I thought only the inner ring plays my songs.
Inner ring include your collection and what you have liked in Deezer.
Middle ring are similar type of songs as you have in inner ring. You cannot add songs there.
I have noticed after upgrading to 2.0.65 the search for updates does not work. Does anyone have the same problem?
Get the message Could not search for updates, server not available.
Also the Link function is not available on the Jukebox, but it works on the App. Anyone seeing that problem too?
It worked for me, maybe servers are temporarily unavailable?
Rel the link function, are you trying to join the Moment to another Multiroom enabled device or or do you want of have another Multiroom enabled device joining the Moment? Second option has never been available on the Moment, only through the App
