The Beosound Moment Beta 2.x thread
Chris wrote:
DHCP reservation
Static IP and static DHCP are two different things,
What we are talking about is coding the IP address of both the SoundHeart and the JukeBox in the BS Moment Network configuration instead of DHCP
mbolo01 wrote:
Chris wrote:
DHCP reservation
I have commented to fast and it becomes a misunderstanding, my apologies.
What I want to say is that at first I have giving both a static IP and realized after a while to better keep my static IPs for printer and servers. So I went for a DHCP reservation later. But I had really no problem to keep my static IPs on the sound hub and jukebox.
np Chris.
I confirm that on my side I had issue keeping the static for the JukeBox, and I gave up at some point. Maybe it was fixed in one of the latest update after I stopped assigning fixed IP, that said it works fine with V2 Beta
An observation:
The swapping between screens have changed. Used to be a "carousel" where you endlessly could swipe between screens.
Now there are 4 "fixed screens": mood wheel screen, "playlist" screen, content screen and search screen. You reach them by swiping either up or down depending on what screen you go from. When you have come to e.g the search screen you have reach the end. You then have to swipe your way back again.
I think that works well.
However, one small thing that is a bit annoying, in my mind, is that when you come to the search screen and the keyboard is up, you have to tap outside the keyboard to make it disappear in order to be able to swipe back to the screen before. Not so intuitive. I have no real idea how to solve it differently, other than being able to swipe from the screen even if the keyboard is up.
I was about to report this to B&O too but then I figured that when you tap the magnifier it minimizes the keyboard. Enough for me but not intuitive i admit
I reported to B&O that some kind of indicators about screen being available above or below, on the right or the left of the current screen would help a smoother navigation.
I have now entered the BETA program also. What a lot of information in the new 'Reports' screen now.
Giving you the information about Loading Deezer tracks TuneIn, battery, DLNA.... its really informative.
Welcome onboard Chris !
How can we become a part of the beta programme?
I just ask to beocare and they say: we do not offer this possibility.
Only if your dealer is part of the testing program I be been told
