The Beosound Moment Beta 2.x thread
I'm actually waiting buying a Beosound 1 and Beoplay M5 till software issues with my Moment and the Beoplay app on Android are fixed.
I guess the number comes from your NAS, as I think it's a combined numer, and if you have Collection album, there might be many artists.
I just tried it out, added a station on the app, then it didn' appear in the list on the Moment, but the I started the last radio station in the list on the Moment, the it was added there.
If you press once in the middle of the Wheel on the Jukebox the music pauses, correct?
If you then change the volume on the Wheel, what are the limits you see?
On my Moment, it goes from full volume to 14 (not 0 as expected). Is that a feature or a bug?
If it is a feature, can someone tell me the idea about the feature?
It is a feature. When there is nothing playing volume regulation is limited so that you can neither turn the volume down to inaudible levels, or up to "acoustic shock" levels.
TuneIn radios I added through the Web UI are now visible on the Moment, I was used to faster refreshes .... Or I'm becoming less patient :-)
Can anybody check if switching off dhcp and set fixed IPs over works now? I never got that working properly....
Regards,
Norwin
Seems to work better. Before only the SoundHeart was keeping its static IP, now the JukeBox keeps it too, including after several power off/on.
I'll keep an eye on this during my tests
Hi Lyle,
welcome to Beoworld.
And thanks for chiming in.
Looking forward to more inputs - if/when you have some spare time ;-)
May the 'troubles' of the Moment users help you to improve the handling of this BS.
Hmm, I never had any problem with keeping a static adress. I have giving it a  DHCP reservation in my Ubiquiti router.
Hi Lyle, welcome.
