I have recenty been "forced" by my internet provider and cable TV provider (COMHEM) to swap my older cabel modem/router for a never:
- Manufacturer: SagemCom
- Modell: WiFi Hub C2
Since the swap I can see constant "red lights" in the BeoTool app , telling there there are a number of inconsistancies (e.g products seeing others as offline) as well as that some products cannot access Beoportal.
These "redlights" come and go, so its not consistent.
I´m not using the built in Wifi. For the Wifi I use two Ubiquiti accesspoints.
Any advice?
Are there ports I need to open? I´m not that good with routers, and I did no reconfig the other router that worked fine with my equipment.
