Suggestion for HDMI to RGB SCART (not CVBS SCART)?
Been looking around for some kind of decent HDMI to SCART (RGB output) and while there several cheap ones available for around 15-26 Euro range from the same manufacturers which produce the SCART to HDMI converters which only makes use of the SCART CVBS instead SCART RGB - I would like to reach out if anyone here has a suggestion for a decent converter/scaler?
Well, it might be
Out of curiosity, what do you need it for, perhaps there is another way?
Hey Kim, I explored this exact scenario a couple of years ago as a way of extending the life of my SCART only B&O gear. The generic HDMI to composite/svideo adapters are universally average due to the limitations of the low res signal.
I highly recommend one of these
I'll try that out as well to connect the Beosystem 3 to my old avant. Sounds like a good solution! Thanks!
Do you know if on the B&O TV it automatically adjusts the screen to 16:9? - I've been using one of the cheaper ones for my BV6 in the bedroom - resolution is not good with Apple TV for text, but okish on a small screen for movies. Problem is that everytime I switch it on I have to then select Format 3 - tried all settings in the setup on both the TV and Apple TV but still end up having to manually switching to Format 3.
May I ask how exactly you generate the 15khz signal from a video processing engine? Kai
A solution to that may be a Beo5/6 which can adjust the format automatically based on source selection on top of controlling the Apple TV and the Beovision.
You'll need something that sets pin 8 of the SCART to 6V (actually 4.5 - 7V) - this should automatically set the TV to 16:9.
(EDIT: It may already be trying to do this, but will only work if your SCART lead is fully wired, i.e all pins connected - have you checked?)
