Subwoofer Solution: Have I found the right choice?
G'day
OK, I went to our Richmond Store today to check out subwoofer options :
> Option 1, BL11 with Receiver 1 (silver)
> Option 2, BL19 (grey)
> Option 3, BP S8
My thoughts about each option are:
With the BL11, I am just in love with the style and design, however, I am concerned that for movies it may not be powerful enough.  I would want a wireless solution, so thought the Receiver 1 would be ideal.
With the BL19, I love the dodecahedron shape and that it is wireless, however, it may be a bit intrusive in the room if I install it next to the Avant.
With each option it's easily programmed by the Avant.
I like the 'cost effectiveness' of the BP S8 and could be "hidden" behind my Avant, but the shape is a bit too much behind the TV
After much consideration, I am planning to purchase a BL19 and being that it is wireless, I can install it elsewhere in the room.  It takes 3 weeks to arrive in Australia, so I am surprised that they don't have any stock.
The reason for my post, is that are there any BL19 customers?  What are your thoughts? Are you happy with it?
I wouldn't consider a BL2 as it's too old, big, and not that attractive (to me)
I watch mainly movies, and listen to some music through the Avant.
At the introduction of BL18, I was planning to exchange my 2005 BL8000 for a pair of those. Not that I don't like my BL8000 anymore, but just to 'modernise' and take advantages of the new speaker techniques the BL18 has.
To shorten a long story, I was a bit dissapointed and expected more from BL18 in comparison to my BL8000. But for the first time I felt enthusiasm for the new BL19. A thing I never felt with the old BL2. Together with my dealer we arranged a listening test (BL8000 + BL19) and it felt astonishing, I was listening to a new set of speakers.
I gives me now everyday a new dimension in listening to my music and movies.
Chris
Thanks Chris. I was also not as impressed with the BL18 as I thought. Maybe it's my choice of music.
But the dealer said the BL11 was not that great for movies - but it looks sooooo lovely
I've got the BL19.  I've found it looks lovely next to the Avant and really grabs everyones attention.
The sound is tight and responsive, a much needed addition to my BL18's, which can't hold their own in movies and even some music.
I'm big time into movies, mostly action, scifi, horror.  I find the sound from the 19 to be spot on.  The thing i love the most is there is little to no vibration due to the dual driver setup.  I find this means i can turn the bass up slightly higher than i would normally and not upset the neighbours.
For music, i'm into a broad mix from pop, dance, electro, classical and vocal.  I find the 19 works really well for all, although i do have the bass turned down slightly for music, as compared to movies.
Overall i couldn't be happier.  Thought i do agree with everyone on the 18's, i wish i'd gone for the 20's and then not even need a sub.
Hey Michael I think a beolab19 would be a great addition to your setup, and like you said having the ability to place it around your room makes it a very good option.
I think the bass from the beolab19 is rich deep and tight.
Why not put the money from the 19 and what you can get for your 8000's, and get a pair of pre owned 9's with that.
Less speakers, for even more bang. And all at the same buck as the 19/8000 combo.
Hi, I think I have said in another thread you should go for the 19 if you were looking to do anything else. I have one and it is everything David King says. Not much more to add. Except my dealer has a 19 under the avant 55 (on floor stand) and I think it looks great! I can't fault it for sound and looks. Integrates perfectly with my V1 and 18's for both movies and music. I wouldn't be without it now!!
Thanks Markidee :-)
Chris T... I don't have 8000s and I don't have any space at the front of room for additional speakers.  I do love those Lab 9s, but now i have heard the 20s if I could fit those in, I would :-)
Dave King, thanks, your review helps me
Thanks Stevegee :-)  Great that you can't do without it now.
I've got the lab2 lab9 and the S8
For the money the S8 is the best bargain.
Imo.
I've bought two as gift sets.
I'm in support of the S8. Especially if budget is a consideration.
