STUCK :-) cannot open front of BEOMASTER 5500 missing user manual
Hello,
Without user manual I am stuck.
I suppose that , in order to control the BM5500  it is necessary to do such from the BM itself. Not from th CP.
I have trouble finding additional info. Does the under half of the front cover ,which does primary touch control, open for further detailed programming??
I may be missing something , but all I have tried to open the cover, has failed. Tapping on the middle seems the most logical LOL
Since I do not intend to use a hammer, I asks you all for your advise :-)
kind regards,
Hugo
You cannot open the front. Only Beomaster 5000 can do that.
You need a remote control.
I would suggest Beolink 1000 for daily use and Master Control Panel 5500 for programming and other functions.
