strange round IR eye
Hello everybody
I bought two round IR eyes on the bay and One of them is a particular model.
The second is like the one we use with beolink passiv (5 connectors on the back and buttons on the front).
The other has the same buttons but the card inside is different.
There are 6 connectors (white instead of green).
This is not a IR eye for beosystem because they don't have buttons.
THis is not a IR eye for a charger of a beolink 7000 because the buttons are different.
It looks like it's another model.
Do you know this model and the way to wire it ?
Thanks for your help.
Best regards
OLivier
Photo???
Ralf
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
Sound like an IR eye with autocontrast.  Used on a BeoSystem with drop down screen, a BV7 with projector where the screen blocks the IR, or an early BV4 without the zit on the top.
Thanks for your reply
I don't konw how to add pictures (I use linux).
It should be for a beovision TV
Don't know what to do with it now.
For a very short time, there were round MCL eyes which look very similar to those used for ML. Similar to the BL 7000 charger but no charging connections. Rare to find. I think they are very nice!
Thanks Peter for your reply
I have read this kind of information by googling, but I don't know how to use it in a MCL system and how to wire it.
Its face is like a normal one, buttons mute on top and play.
It's useless for me at this time.I just need an IR eye for a beolink passiv.
Any more information/datasheet welcome ;)
I asked to someone who owns a IR eye for a beovision and he tolds me that there is no buttons on it.It is just a receiver.
So, I just have to discover if the MCL round IR eye has buttons and how to wire it.
The story goes on ...
Photos:
1. Choose to post/reply as normal
2. Click on the "Options" tab near the top of the compose screen
3. Under file attachment select "add/update
4. Browse directories, upload, etc.
OR
1. Compose message as normal
2. Select "options" from the tab
3. Under file attachment select "Add/Update"
4. Enter the URL where an existing file resides.
OR
1. Compose mesage as normal
2. Select the image icon from the formatting palette
3. Enter url
Thanks for your answer.
On my system, I cannot browse my directory if I use your link.I use linux mint and Firefox
The seller of this IR eye, just told me that it is for a beolink activ.
Are they different compared to those for beolink passiv ?.
kallasr wrote:
Photos:
OR
OR
3. Enter url
or,
-open the picture in another application
-select all
-copy
-paste into text box
