My grey BL3 has developed over time a very fatty/sticky coating and when i try to remove it with water and soap it builds up into very mushy texture....i'm not sure if there is some protective coating on BL3 that is disentragting and i just need to work hard on trying to remove....anyone has had simillar problems?
Otherwise; is it possible to get the shell removed and paint it? I thought i had seen some posts on this in the past but i can't find it using search which is giving me 900 pages of results on BL3 and paint, cover etc....
Thanks in advance!
Klas
