MCL2P with Original Instructions and the 15v cable for powering MCL2AV,I did not expect the 15V cable to be gray, but what do you know. On the other hand these connectors was also used on the Beolit power supplies so they might have had plenty in stock.
I did not expect the 15V cable to be gray, but what do you know. On the other hand these connectors was also used on the Beolit power supplies so they might have had plenty in stock.The connectors are actually a little strange - the external contact has a small plastic sleeve on it that will slide up and down. I am not sure of the purpose, but it does need a bit of force to push it into the MCL2P socket, whereupon there is a positive 'click' once fully inserted:
The connectors are actually a little strange – the external contact has a small plastic sleeve on it that will slide up and down. I am not sure of the purpose, but it does need a bit of force to push it into the MCL2P socket, whereupon there is a positive ‘click’ once fully inserted:Interesting with the design of that connector as the connector I am using for mine is not sitting very well in the socket, and as the MCL2AV is designed to have the connections downwards this design would sure help to keep the the connector inside.
CD not working!!! It tries to play and then I get the < > (no disc) display. I took the back off and put it in test mode. The CD tests all run smoothly will the laser coming on, trying to focus and full linear movement up/down. Trying to play CD in TESTMODE then gives a Focus Error 2. I’ll investigate further but possibly hijack your Ouverture CD thread, as I think it’s the same CD moduleSounds like some of the same issues I had. Although I dont thinkt the focus error appearead on my ouverture.
I seem to remember seeing something similar in white before, but can’t remember what it was for.It's familiar to me too! Perhaps used to push a hidden reset button, or as a depth guide when drilling holes?
I actually discovered that I have one of these connectors, so I might as well put it on my power supply for the MCL2AV to help secure the connection better.It's also the same size as the connector on the , although I replaced mine with a PL plug, I kept the plug, and just managed to find it in my 'small spares' box. The 'extra' black plastic sleeve is in a fixed position on the remote switch plug: Login to view image
link Have you tried testing the MCl2P yet? I was wondering if the 15V output for the MCL2AV is always on? I guess I has to be on in standby for the MCL2AV to be active, and then the MCL2AV can wake the MCL2P from standby via powerlink.Just testing it now (prompted by your post, and the fact that my wife is out so I can use the living room!) Yes the 15v (measured 14.75V no load) is always on. One thing that I remember from before is that the BC2300 will not 'mute' the MCL2P, despite using a fully wired PL cable. I have a(nother) Passive arriving in the next few days so I will check mute with that also. Easiest passive speakers to access for test were my Audiorama 8000s, still in their Winter blankets! Login to view image CD still not working - must crack on with that task ...
This might be related to the fact that the MCL2P only use pin 1 in the powerlink connector for powering up. This thread https://forum.beoworld.org/forums/topic/powerlink-power-up-vs-speaker-on/ mentions pin 1 as powering up and pin 4 as a mute function on older powerlink speakers.Yes I think you are right - I was just working my way through the service manuals to remind myself of the powerlink pins. I also just checked two different PL leads with the multimeter - one was fully wired and the other had all except pin 8 connected. I'll let you know when I check the Passive EDIT: And I just found my 14-year old post on the same subject! /forum/general-discussion-and-questions/is-bang-and-olufsen-in-trouble#post-2130714
