Still no PCM sound on updtaded BV7 !!
I'll do it right now !!!
7.1 doesn't seem to work either in a Mark3 is it meant to?
The B&O Technicians left only a few minutes ago.
And actually I am quite sad right now. B&O Germany said to my AD it is not possible  to update the BV 7-32. I asked them to do the update because I thought I knew better. Today they dropped in the new chip
So the new settings of my TV are:
AC3 SW 03.01a
06 IC3 AP SW 7.2
06 IC2 IOP SW22.0
Type 9331
M2 07.91e
M2BOOT 07.10a
But - it does NOT work
The Type NO. of my TV is :9331
The Item No. is :1817755
The technician guessed that it could be possible, that german TVs have different DSP-Boards - He will try do find out what the reason was why the update did not work.
All who are interested: I'll keep you informed
I think an important information is the customer Service Menu. In the first Post of this thread mad says:
"I have PCM settings in Customer Service Menu"
My BV-7-32 does not have these settings - so it could be the case, that there is a different DSP Board in the TV.
Sad but true :-(
In my Customer Service Menu there is only a Setting:
Adjustments/Sound/AVC On
There is no setting for PCM
It would be if your AP SW 7.2 is updated. This one can't be flashed.
