Stb-controller for Motorola 1910
Could someone please direct me to where on this site I can find info about stb-controller chips (I have silver membership).
I would like to know if the chip for beosystem-1 that holds codes for Motorola 1920 also has got 1910 on the same chip or if they are on different chip versions...
Hi, you can find it here:
ok thanks!
On the other hand, have you tried using 1910-9 settings on a 1920. Often it works fine, it 's just some functipn that might not be availible.
I thought so also, I have no experience other than that I tried different sagem list-items forcontrollers for my current old Sagem-box that I had in a drawer but none of the names in the list worked. I will check with the chip I already ordered anyway.
