STB-C /MX/decoder problem
OK, I would be delighted to hear that if its the case as I have one that is set for Sky and would rather it was for something a little more useful to me.  My understanding was that both the DVD-C and STB-C for the MX range could be set once only for life.  Perhaps I will give this a try!
Neil
As for the DVD-C, I've used it for Philips and for Onkyo. Had both the MKI and the MKII.
Both uses the same way of programming.
Is there somebody here to answer the other questions I have ?
  1. Is there an official & updated B&O list for STB-C code ?
  2. Is there a way using the Beo4 to know the current value of the entered code ?
  3. Is there a way to know the current STB-C chip version embedeed in the MX ?
  4. same with the version of the MX software?  is there a way through remote control to display software version ?
  5. As a consequence is there a correlation between MX software & STB chip version to provide correct functioning ?
 thanks in advance
regards
The lists are available here.
