Hello everybody.
I'm french. I'm new here in the forum (a couple of weeks). Recently I bought a beautiful & perfect black & white "second hand" MX 4000 with Beo4 remote control. it includes STB-C hardware and a wire to connect to a decoder (in my case a sagem decoder for french digital broadcast tv (TNT)).
I had a look at the manuals section and found some useful documentions but .. I'm still having problem with this configuration. my Beo4 don't drive the decoder. So I have some questions for you:
- Is there an official & updated B&O list for STB-C code ?
- Is there a way using the Beo4 to know the current value of the entered code ?
- Could we change the actual code ? I ask this because manual indicates
Set up the Set-top Box Controller
"Make sure your set-top box is switched off before you activate the Set-top Box Controller. This is a 'once only' operation." - Is there a way to know the current STB-C chip version embedeed in the MX ?
- same with the version of the MX software? is there a way through remote control to display software version ?
- As a consequence is there a correlation between MX software & STB chip version to provide correct functioning ?
=> For example in my case, if I look at decoder Sagem ICD4231 as a reference, depending of the STB-C list, I can find different codes:
- code 24 (table 3.81)
- code 22 (table 3.91)
Which is the good one ?
many thanks in advance and I appologie for my poor english
Flamel
