To Beoworld experts
I have got a Beogram 8002 problem
is when I press start, then tangential arm moves onto the plate and stops one cm before the plate.
The tangential arm then runs back completely.
The tangential arm's running machine is not blocked,
with the buttons, manually can drive it all the way to the end of the disc and back again.
It's as if the record player thinks no plate is on.
I've divorced the runway from each other and greased it and it runs easily.
Can any electrolytic capacitors that can go in and send incorrect information be dried out?
Regards Ulrik
