hi all,
i have just purchased a Beovision 7 40'' mk 3
i need to remove the stand for transportation,
does any one know were to start, is there specific tools required ?
any help much appreciated,
cheers.
hi all,
cheers.
Good evening,
First, find the owner's manual. The B&O site must still have it. The procedure is described here. You will need allen keys. Don't forget to disconnect the speaker from the TV.
Two persons are required to move the TV. Don't hold it by the glass, it will break.
Good luck,
Jean
