Stand along Beolab 5 & Beo 5 Configuration (help)
Help, help...
I have an stand along Beolab 5 (No beosystem)
It says in the manual that a Beo4 remote is required in order to setup options(0,1,4) , change line levels (2~4V RMS), and store settings,...etc.
The functions in Beo4 such as the "OPTION?" or "SOUND*" are missing since there is no "LIST button" to press in Beo5...
Is there any code for programing these? or is there any documentaion for the extension/combination codes of beo4ex ?
Thanks.
Wouldn't it be more practical to simply go and buy (even an older, second-hand) Beo4, given you don't have much other B&O? (You have Beo5, right?)
