Spotify now integrated into V1, BV11 and BV12NG
Will they get Deezer instead ?
Peter
It's a pretty bad app on the BS4 anyway, do many people actually use it?
There is already Deezer on the BV11 platform?
I use it once in a while - and I know someone, who often use it.
But we will need that information to be verified - otherweise I'd call it fake news ;-(
Removing it would not be too bad....if we could get support for Spotify Connect instead.
MM, my thoughts exactly- thay can't just remove a feature, without replacing it.
Peter
Peter
Spotify are in charge of what plattforms they want to support and not B&O.
I can confirm that Spotify will be removed from Beosystem 4, Beoplay V1 and BV11. The "app" or web solution has not worked fine at all. I think it´s a really good opertunity for B&O to deal with Spotify and finally be able to distribute Spotify-Connect from a Beoplay A6, A9, M5 or Beosound 35.
Do anybody know why you aren't aloud to distribute the Spotify-connect stream in the Beolink Network? I mean know we can even distribute Airplay from Apple?!
@spezialisten
What does 'confirm' mean?
Can you qoute an official B&O announcement of the removal?
Good riddance. Using Spotify on the BV11 makes me want to throw the remote control st the screen every single time. Even my Mini in-car system has a better implementation.
Millemissen wrote:
@spezialisten
It's confirmed. Spotify will be notifying everyone via the interface they are using. It's not just B&O that are loosing the app, a lot of other players are as well.
