Spotify now integrated into V1, BV11 and BV12NG
Hi all,
Exciting news - if you have a V1, BV11, BV12NG or BeoSystem 4, there is a software update you can download now to get Spotify integrated straight on to the TV. It shows in the menu as a source - and you can assign any button to it on the remote, such as CD.
If someone can explain how I can upload a picture onto BeoWorld off my iPhone, I will post pics :)
Thanks for the info! Would like to see a picture but I am also not sure how to post a picture from a phone.
This is great news - if Spotify would go lossless it would be perfect.
How about the BeoRemote-app? Is that/will that be updated too - to get navigation direct within the app?
One way of posting pictures is to add it when pushing the 'Reply' button (not the 'Quick Reply').
But you must get the photos to your Pc/mac first - easiest way is using a cloudservice.
If an Android phone all you need is a usb-cable to the pc.
There are cloudservices that create an ip-adress for a picture.
This one you then would have to put in between two IMG's with [...] around them - the ... stands for IMG
Sorry, only way ro descibe it - otherweise it won't show in the post
Lke this:
The adress of the picture was: http://maloki.se/wp-content/uploads/2013/09/spotify.png
Greetings MM
I can confirm that the app does work with Spotify - it shows as a source under 'Media'.
I couldn't get it to bring up the keyboard though - that would be a nice feature.
Thanks Martin,
but how can you navigate then?
Old story with creating 'playlists' on another device/in the Spotify-app first, then???
You can navigate using the Beo4 or the RemoteApp. Playlists are avaiable butyou can also search artists, songs etc. When searching a small keyboard pops up, where you have to punch in the letters individually using the navigation buttons. The RemoteApp does not give you a keyboard for that. Other than this it works extremely well,very responsive application with a decent layout - a nice addition indeed.
Like he said :)
I made a Beo6 config that also gives easy access to speaker groups and sound settings.
This is exciting news!
I immediately checked my BV1. The upgrade has been done but I can't find the Spotify source. Do you need a key to activate this? Or should the 'webmedia' function be activated already?
Any feedback is much appreciated.
I also noted that the section with 'usefull Information' à chapter on Wireless speakers has been added.
Try pushing 'CD' on the Beo4.
I only have Beo5 so I can't try it. Shouldn't Spotify show up in the sources menu?
