The app is made by Spotify so blame them. It's a bad HTML-based solution I think. And while you're at them, ask them to make an Apple TV app. I can't believe how they still don't have one(!).Everyone seems to be raving about spotify integration on for example the BV11. It would be great if the damn thing would playback Songs gaplessly, however it does not! Stuff like this really annoys me. My mac mini with KODI installed on it does it perfectly, and I would think a high end brand like B&O should have no problems with it either!!!
Spotify now integrated into V1, BV11 and BV12NG
For me, Spotify does not work at all anymore. On my BV11.
2 Seconds and it stops.
The Spotify menu is so slow on the V1 that I've put a chrome cast on the back of the TV. I must try it!
One week ago my V1 started having the exact same issue. After around 56 seconds, the music starts scratching, and play/pause can get it in sync for another 56 seconds. The problem, however, can sometimes be solved by simply turning the TV off and on.
Spotify will soon be removed from the BeoVision 11, BeoVision Avant, BeoSystem 4 and Beoplay V1
Where is this information coming from ?
peter
