I have a perculiar issue after having done a "spotify upgrade" on a BV11-46 with a BL11 attached as subwoofer:
After turning on the TV, the BL11 connected to the BV (as SUBWOOFER) apparently receives no signal from the BV. Speaker settings look fine (ie. BV11 appears as SUBWOOFER under SPEAKER GROUP, TV) but the BL11 is not receiving any signal. Mystically, the output/bass signal to the BL11 is restored, if I select "Speaker level" under the SPEAKER GROUP menu. Just entering the "Speaker level" submenu will do the trick, no changes in speaker level is needed. Unfortunately, after turning the TV off and on again, the problem reappears - no sound from the BL11.
Obviously it is quite annoying (to say the least) to have to go through this "reinitialisation process" every time the TV is turned on.
Anyone experiencing the same/similar issues? Looks like a software glitch?
