crossbytje wrote:
I'm a bit confused.
The Spotify connect functionality works on my M3's. I received the updates yesterday.
As it appears, Spotify does not allow you to play to more than one device simultaneously (which is apparently standard behavior). That was previously possible if I selected airplay from my phone, but that required the phone app to be running and draining battery. Also L/R channel separation was impossible. Then came the Chromecast stereo pairing, which allowed to use my pair as a stereo pair. I thought that this also required my phone to be actually streaming constantly, but as I tested today, I can shut down all my devices running Spotify (phone and computer) and my stereo pair keeps playing uninterrupted!
I can also use my BeoRemote One, the B&O app, or any other way to skip tracks, play/pause, volume control etc.
Makes me think, what were we waiting for? Where is the added value of Spotify Connect if it already worked through the Chromecast built-in?
What you describe as the behaviour for using AP2 or CC with the B&O (and other non-B&O) devices is correct - as also Sandyb writes.
This is well-known and used amongst B&O-users.
What makes the use of Spotify Connect (with the supported B&O devices…..which seems to be all now) different, is the possibility to multiroom the stream via Beolink.
Whereas you - with CC - will have to make static groups in order to have multiroom and - with AP2 - will have to add and disconnect the devices outside the Bang & Olufsen app, you can do this within the Bang & Olufsen app, via the beoremote or directly on the devices (Join). And you can add/disconnect the devices ad libitum rather easy, if you need to.
Yes, you can do beolink-multiroom Spotify using AP. But at least in my setup it does not work as well as with the Connect version - and Android users can not use AirPlay. I wonder if there is metadata/cover showing on a Harmony/Eclipse (?).
The only thing you must do - which is the difference to using the built-in Deezer - is that you will have to choose your music in the Spotify app……once that is done you have the full beolink experience just like with radio listening etc.
In case you - like me - have one or more BV’s from the BV11/AVANT 1. Gen/V1 generation, these also can be a part of the listening experience….just like with e.g. an A9.
Some people like the UI of Spotify more than the UI of the built-in Dezzer (in the B&O app) - however, that may seem a personal choice.
AND - if that is as important for you as for me - Spotify Connect (and Spotfy Connect/NL) allows for gapless playback.
Sandyb already mentioned that - for me that has always been a main reason to stick to Spotify (try listening to a Pink Floyd album from Spotify either via AP or CC….that is not what was meant with these album).
So the added value is, that you can stay within the Bang & Olufsen experience - this might be trivial to some users, but it certainly matters to those users, who use beolink multiroom……and prefer Spotify as their music streaming service.
(Looking forward to the day, when Spotify starts their long anounced HIFI/lossless version).
All in all….there is not really anything new about it - apart from the fact that now a lot more B&O devices have support for Spotify Connect built-in.
Whether someone will benifit or not, will heavily depend on his/her setup and his/her user behaviour….maybe that someone likes to engage Hey Siri or Hey Goole when listening to music!
To showcase what the difference is (when you prefer the B&O experience) please look at this picture from my setup.
One showing a Spotify stream via Connect and the options to add/disconnect my devices - the other showing the same Spotify stream via CC….no possibility to add the devices directly there.
