BOTF #shorts Bang & Olufsen just released new software update Spotify Connect to many speakers
Spotify Connect arrives in alot of B&O products
Yes π
Discussed in this thread
Does B&O provide some CHANGELOG file? So we know exactly which products will be updated and what are the changes?
For example I have a non-GVA BeoSound 1 gen.2 and there is no software update..?
Thid they add it to Stage and Edge ?
Isn't it possible to write a simple text with all products? MUCH faster and convenient than a video. ;-)
Sure, but Henrik is just showing what he can do in that setup - and for a lot of people seeing makes it easier to understand than reading about it.
However, feel free to make the βtextβ - would be nice to have ;-)
According to the discussions here on Beoworld and the short video (with good music by the way) the following devices have the update:
- M3
- M5
- Beosound Core
- Beoplay A9 MK1
- Beosound 1 / Beosound 1 GVA
Please feel free to contribute if there are more devices with spotify connect (re-)enabled.
Very interesting that the A9 MK1 is supported again... as spotify support was removed in 2018 which resulted in some angry customers:
https://community.spotify.com/t5/Other-Podcasts-Partners-etc/B-amp-O-and-Spotify-Connect/td-p/4393407/page/3
A VERY positive move from Bang & Olufsen to listen to their customers and bring back the functionality.
Old & new version numbers, or it didn't happen. (Echoing the car-repair boards where pictures are de rigueur.π)
Ex: My BeoSound 1 Gen.2 non-GVA in North America has not moved from 1.11.45905 for months. Also cf. @libor, above. So delete or qualify the BS1 entry. (Knowing that in the other thread his BS1 gen-?? GVA went to 1.10.xxxx but @Hiort did not actually test to see if Spotify Connect was supported(?) is not definitive!)
M5
- New version: 1.27.47107.120390320
- Old version: 1.26.45904.61640457
M3
- New version: 1.12.47109.120390320
- Old version: 1.11.45906.61640457
Beosound 1 GVA
- New version: 1.10.47110.120390320
- Old version: 1.9.45907.61640457
Can confirm that Spotify connect work on all devices and you can use the multiroom screen in the app to distribute the music.
Login to view imageCan confirm that Spotify connect work on all devices and you can use the multiroom screen in the app to distribute the music
Register to access the forums, reference material, and exclusive member benefits β including our monthly prize draw.
