It took me about 3 hours to setup and assemble (!) the Beolab 20, Transmitter, Beolab 17 and the Beosystem 4 and it does not even work. I don't even understand why each piece comes in several pieces and needs to be assembled - it felt like Ikea, only in a completely different price category. The worst part is the IR-Eye, which needs to have its cables wired.
When you connect the IR-Eye with the Beosystem 4, you see: nothing. On both devices there is not a single LED to let you know if it's on or off. I called up the dealer ("don't know"), re-wired the cables, but still nothing happens. Seems like somethings broken.
I was initially thinking of spending another 15.000€ on B&O (Beovision etc.), but if this is there quality management, then I will have to return all of this and buy into a reputable brand again.
But before I lose all hope: does somebody here use the IR-Eye with the Beosystem 4 and can explain to me the required wiring?
