Speakers for beosound 2300
I am looking for some speakers for my beosound 2300 any ideas ??and I want small and black and around £200 figure
Hi JONNIE
You're going to struggle somewhat with a budget of £200. That certainly rules out any active speakers (speakers that have their own amplifier built in) such as the Beolab 4 and Beolab 4000.
On the Passive side (speakers that use a seperate amp) you could go for a pair of CX50 or CX100 and use an amp - either a B&O MCL2P or another make of amp (I use a Quad 405-2 with my 2300). With the CX speakers you'll have to be prepared to re-foam the drivers. MCL2P amps normally go for around £200 on their own but sometimes go for less.
If the budget is strict I would go for a Quad 303 (£110) link
CX100  in need of re-foaming (£50)  link
link
and then connecting lead and new foams (£50).  link   link
link
The great thing about doing this is that at a later date you can add a B&O Cona sub-woofer (about £120) which will greatly enhance the lower frequencies.   link
Good luck!
Cheers
Nigel
EDIT - checking on ebay MCL2P price now seems to be £60 - £70..... Someone else posted the other day that prices seem to be falling and it definitely seems to be a buyers market....if I hadn't bid on this , it would have sold for £107.......
In my opinion the Beolabs 2500 are worth a try" http://www.beoworld.org/prod_details.asp?pid=368
These are active speakers and should be available second hand for less than 200 GBP. They do they job well and they fit the Besound 2300 very well!
Don't think I've ever seen a a pair for less than £250 and they're more usually this sort of money link
But if you can stretch to whatever you can find a pair for then yes, wasti is absolutely right - this would be a very good, simpler and aesthetically more pleasing option! (Either solution would be about half the cost of the Beolab4 option you were exploring in another thread and accoustically just as good)
If money is really tight then you could always consider  - £150 seems to be the going rate at the moment
Cheers
Nigel
I wouldn't even dream of using Beolab 4's, they're only any good as PC speakers IMO.
Beolab 2500's are easily going to be the neatest & cheapest solution which will fulfil your needs. I agree with Nigel though, you'll struggle to find any decent ones for less than £250 (minimum).
As for Beolab 2000's - does the 2300 support masterlink? You need this for these as they are only link speakers - I have a feeling you may need to add a converter which will push the price up towards the cost of some BL2500's.
Chris.
Cheers guys I was going to go for beo4 pc (some guy said he couls make a lead for me to connect to 2300) as was only for kitchen but I think will need to stretch a bit and go with 2500! speakers!
