Hi folks I have two BL6000s as rear speakers which are daisy chained. I am not sure that they are set properly to left and right (via the switches at he base of the speaker). Other than lifting the speakers up and checking that the switches are correctly set to right and left (which is very awkward for reasons that I won't go into!) is there an easy way of checking that I have them correctly set? When I check the speaker levels on the TV, each speaker can be adjusted separately so I am guessing that they are set correctly. I just want to make sure that on 5.1 surround sound, I am getting the correct sound to the right and to the left. Thanks for any help. C
Speakers - left and right settings
Hi,You can use the speaker Command of the beo4 and tuen use the left wand right Button to check. The Balance right/Left. Them. Press Exitus to Peace speaker Mode.Hfat
Thanks for the help Hfat, much appreciated! Cheers C
Hi Compostelle,
I've just read my posting. I'd better turned off the auto correct feature of the iPad i used to post.
You must be a genius to understand what I have written :-)
hfat
