Speakerlink cable specification
I need to make up some SpeakerLink cables.  I know about the 4 pin DIN plugs that are required but can anyone point me to a suitable 4 core screened cable ?
Alternatively, 3 core with screen would be OK too.
I guess this would be a stranded multi-core cable but I like to know the size of the cables (in mm)
Use multicable 6 wire with one wire screened.
Cable should be 0.5-0.75 mm for each wire, 0.2 mm for data..
See link below:
link
Thanks very much for the information.
I have beenable to find a cable specification from the BeoInfo site.  The wiring referred to is as mentioned in the links previously shown..
A possible cable is a hybrid power and signal cable such as, for example, Van Damme Ambicore.  Clearly there are other manufacturers.
