Speaker Suggestion
Hey All
I need a speaker suggestion.  I have an Avant, BL2 and BL8000. I'm thinking about getting rear speakers.  Also I'm considering getting a BeoSystem 3 for my 40 inch LCD and putting BL8000's an BL2 to it.  So in either set up which rear speaker would be best.  Thanks
Hi brendon,
the rear speakers are not so important for the sound experience. I would go for a non-expensive pair of speakers. As I read in other threads, the latest ICE-driven speakers do not combine well with the BL8000. My latest setup consists of BL8000 as fron speakers and RL60.2 (with Beolink Passive) as rear speakers - though the RL60.2 are oversized as rear speakers... but they were a bargain on ebay.
I have a similar set-up where I had 6000's as rears but swapped them for 4000's on stands. The 4000's are an improvement. Maybe to do with them being the correct head height, whereas the 6000's were firing into the side of the sofa. Generally I think the 4000's sound better than the 6000's. I guess it depends on room layout but for the money I would say 4000's would do the job satisfactorily
Get the 4000s. They'll go well with your BL8000s. Mount them on stands or up on the wall behind your listening position.
I haven't heard the new ones with ICE and don't know of any incompatibility with BL8000s, but if that's an issue then go hunting for a pair of used ones. These speakers will outlast me and used ones will do an excellent job.
I'm gonna vote BeoLab 4000s. If you use BeoLab 6000s, they often end up firing straight into the back of a sofa, or other furniture. BeoLab 4000s can be mounted at whatever height you want.
Bear in mind that the BeoLab 6000s can be wall mounted now though, if you want to go for them instead, although as others have said, the BeoLab 4000s are kinda slightly better.
Like others I would suggest the Beolab 4000's as your rear speakers, in fact that is exactly what I have in place and have had for many years.
Definatly go for 4000's, had mine with the same 8000's front  for three years and its a perfect sound!!!!!!!!!!
I love the sound of the 4000, but with a pair of BL9 as front speakers and an Avant, Do you think the same? Would you choose the BL4000 as rear?
Ok, one vote from the 6000 camp (looks like I'm in the wilderness compared to the 4000 support 🙂) but I have my 6000's in line with the back of the sofa so they are about 100 degrees around from my seating position and much more involving than the wall mounted Mission 77DS they replaced. These are coupled with BL9 mains and BL7-4 centre, now when does the full-HD BV4-50 hit the dealers...
