Speaker grill cloth
Does anyone have a idea of where to get special "speaker grill cloth"
I just bought a Orange Speaker grill for my BV10 40", but i think maybe it´s  a bit to much, matching the sofa pillows.
And now played with the idea of making one with burberry cloth/fabric like this.
But i can´t find anything but black,gray, white, green, blue ect ect........
I dont think the fabric is out there, but please notefy me if you know anything ;-)
Think you simply have to do it yourselves. Or have e.g. a furnituremaker do it for you. But you would probably need to buy a black speakercover from B&O, for them to use as frame. Probably the cloth you use has to be quite thin, in order for the sound to come through properly.
There are quite a few vendors if you look on the web (http://www.akustikstoff.com/Acoustic-cloth-design-print:::9.html
Whou.. The dutch site, is the solution i think...
Regarding the speaker plate. I will use the orange one, to make the new one.:-)
