The way I see it, then B&O lack a stand for high TV-tables.
The current choices are either the low backwards tilted stand and the upright high stand. Both of which aren't ideal for a high TV-table (50-60cm) as you will watch the picture from below. The high stand will also force you to look up all the time, which at least for me becomes quite uncomfortable when watching a movie.
This is of cause only a problem if the color reproduction is changed when watched from below, which will surprise me if it isn't the case.
So I fear that in order to get the best of the TV, I need to replace my furniture, which to be honest feels a bit wrong :(
I see the problem for B&O, as the tilt on the low stand is needed for stability. But I really don't want to compromise the picture.
