Just realized that BeoLit 12 has 120w total amplifiers and 2x2 inch tweeters and 4 inch woofer just like the V1-40. I think it might be the very same setup. What do you think?
It says on v1 tech specs that it has support for dolby 5.1 and dts 2.0. Does that mean that DTs only works for a stereo setup? I like DTS and always choose it before dolby digital. And no HD sound codec support either.
Perhaps Geoff have a good answer for this. I would even pay extra for licence to play these codecs that my old yamaha rx-v3800 play without a problem since I bought it five years ago.
I do like it anyway but I want it to work as good as it can. It has better sound than much else so the software should not be limiting the software, right?
It can take PCM audio so I guess if the bluray player or whatever can convert HD to PCM that it is ok anyway?
PS. I will probably get my V1-40 next week according to my retailer :) happy anyhow and I think the sound modes are genial. And I think the technical spec sheet on beoplay.com is wrong, it certainly looks weird at least with large fonts mixed with normal.
