Sound quality question: Eclipse/powerlink with BL50 vs BS Core/optical out to BL50?
I have today a pair of BL50 connected to an Eclipse 65 with powerlink.
When listening to Deezer/DLNA Music, will the sound quality be better if I buy a Beosound Core and feed the speakers directly with Optical cable between the speakers and the Core?
Best regards
Sweden
Better how? Better to listen to or better measurably?
Compararing two experiences will always be very different, mostly due to the small differences in the sound pressure level and also the differences in the processing in the BV (you’d have to be very carefull there).
Also our memory of listening is very short and the danger of prefering, what is ‘supposed to sound better’ is big.
So, better....hmmmm - I am not sure, what that means. But the sound might be different!
Unless you are someone who sits down a lot and listen a lot to music, I’d go for the comfort of a connection through the BV.
However - as always with music/sound - try out things in your own room and pick what you like best.
Hi guys,
My thoughts was IF Beosound Core with optical out directly to BL50 is a better solution regarding adioquality vs Soundcenter in the Eclipse with powerlink.
There are less D/A coversions when using a digital source directly to BL 50.
But maybe there are so little difference so it is an unnessery investment in the Core.
IF someone have tried both setup:s as described above then please give your opinion.
Best regards
Tidal sounds better streamed from iPhone to airport express with optical. Than tidal app on apple tv 4k. More clarity and better image. Even the bass in tighter.
Orderd a bluesound node 2i. Testing it this weekend.
First impression with bluesound node 2i. The phantom center is more pronounced. Wider sound image. And last but not least even clearer sounds throughout the register. The bass is clearly tighter, less boomy.
I quite liked the Bluesound interface when I tried the Node 2i.
/forum/general-discussion-and-questions/a-day-with-a-bluesound-node-2i#post-2140323
Currently: BeoLab 17, BeoLab 18, BeoSound Core, BeoPlay S8 Connection Hub, Essence Remote
Previously: BeoSound 1 non-GVA
And you can turn of the light on the streamer. I wish b&o would listend to me when I told them I would like to turn of the light on the beolab 50.
When playing keith don’t go. Every gitarr string note is like a bullwhip in your face.
When discussing the Node 2i, some forum peeps suggested it’s not really that good a streamer and not a reasonable partner to BL50. They suggested Lumin or Auralic. Those are about 5x the price of the Node 2i... maybe it’s worth it? Maybe not?
