Hi all,
I have a pair of BL2500 plug to my Ouverture. For the one who have chance to compare BL2500 versus 4000 did you noticed a really big difference ?
Thanks for your feedback
Franck
Hi all,
Franck
Yes - I did!
Yes - I did!
Edit - had to say it twice 😎
And ? very big difference ?
Thanks !
Franck
Yes - I did!
So did I!
Great Speakers, the Beolab 4000, and so many options to set them up: wall mount, floorstand, horiziontal table brackets, vertikal table brackets*
Ralf
*: actually, looking for the Standard table stands, so if anybody has them for sale...
Yes, there is a difference.
It's more or less the size of the speaker, bigger is better.
But also the electronic sound path, the 4000 has a little bit better electronic parts and design...
Both can be upgraded, pretty easy the BL2500, the 4000 a little bit more material. Both sound superb after the upgrade.
How? Look and find it in the old archieved workbench forum... everything you need :)
Hi and thanks both of you but really I'm sure to breake my speakers if I try to do so...
I nerver modified any electronic device so...
Anyway thanks for this good link, perhaps one day I will make the jump... or change to a BLxxxx I will see.
Have nice day
Franck
If you have never modified any Electronics, then my advice would be: don't try.
My answer to your first question is: The 4000's sound much better than the 2500's.
I know the 4000's are supposedly active, in that they have two amps and an active crossover, but did the 2500s as well, or were they like the Pentas, amplified but using passive crossovers?
