Sound adjustments Beocenter 2 + Beovision 3
Hi everyone, last saturday they installed my ´new´ Beovision 3. It is connected by a masterlink cable to the Beocenter 2 and 2x Beolab8000. There is one problem, if I want to adjust the bass and treble from the Beocenter 2 the display shows that I have to do that trough the Beovision 3. But when I change that I also change the sound setting from the Beovision!!?? It is not possible to have separat soundsettings for Beocenter 2 and the Beovision? When I listen to the radio or cd I have +1 for the bass and +4 for treble. When I watch tv. I always had +2 for bass and +3 for treble.
Thanxx.............
Have your loudspeakers connected to the BC2! If you want to have sound from your TV/DVD, put the BC2 in option 1
and to acsess the TV's sound, press list+av+(the source) TV.
I had a similar issue when i masterlinked and connected the speakers to the TV. Besides, the sound from the TV's board isn't as good at the sound from your CD player.
I guess I have to compromise between the 2 settings (Beocenter 2 and BV 3).
One thing I noticed this morning is that when I turn on the BV 3 I can hear a sound coming from it. Sounds more like `a computer sound`. Then the sound is gone and the curtains will open and then you get the normal sound from the selected channel. The souns isn´t deep sounds more like´breeem´. Anyone who knows what this could be? Should I worry? Is it normal (surround module or something)
Gr. Conan
