Sony TV - Audio output to masterlink
jleckenby wrote:
Not really sure what you mean.
I have the beolink connected with a figure of 8 power cable, aux cable and masterlink. Do I need something else?
Would be helpful to be more specific...
What AUX cable did you connect? You would need an adapter fpr the whatever TV headphone out...? Wiring?
ML is directly connected to the audiomaster (BS3200)? BS3200 set to A.OPT2?
If you select a video source with RCU (TV, DVD...) in front of your audiomaster does it turn on?
Did you install the 1611 (?) converter - a BL Video 1615 wouldn`t work in the scenario - by connecting ML cable and the mains?
Does your BS3200 turn on (to video source) if you select a video source in linkrooms?
Stefan
jleckenby wrote:
Yep, I have a Beosound 3200 in the living room also, though nothing connected. It's just to power the A.AUX and radio for everything else.
Why not use the AUX socket - should be one on the 3200 - for the TV?
just cut the ML plugs from the ML cable that connected the BV and solder a 7(5) pin DIN plug for the AUX socket and a whatever plug for the whatever TV. You can use the audio wires...(you will only need three wires...) And you wont need a BL converter...and no extra mains socket...) :)
Stefan
I'm using the aux cable I used before to connect my Beosound 3200 a.aux to an airport express (3.5mm). Surely that's not an issue though? Wouldn't the TV source work just with no sound if it was?
Can't use it for TV as its on the walll and would take a lot of work to get a cable from stereo to behind TV.
I'm not really sure what the rest means, sorry, newbie! Basically I have a Bousound 3200 and a few BeoLab 3500s all connected via masterlink. I've replaced a Beovision 7 who the masterlink worked with.
Hopefully that makes sense!
As for the converter it is a BL Video 1615. I'm basically looking for any BeoLab 3500 to work with the TV source. Don't need any control of Beosound 3200 in the same room as it has no speakers.
I don't know if this helps, but the Beovision 7 was the master (I think thats right, its where I configured everything like timers). Thats what has been replaced with the 1615.
As said before. BL Video 1615 won`t work - see my first post.
Try the 1611 converter or the AUX cable solder solution...
Stefan
Hmm, what would a normal setup with a 1615 look like?
If I bought a 1611 would that respond to the tv input?
The answer is quite simple.
The 1615 is built to connect a link-Tv (non ML like old LX/MX-BVs) to a ML setup.This is why it`s called Beolink Video.
Therefor it only transmits audio from ML side to AAL (audio aux link) side in stereo, and it sends control signals from AAL to ML
- with one exception: system stdby command can be sent from everywhere in the setup and even to link-BVs.
This device won`t help you in your setup - as said before...
1611 Beolink converter is built for connecting audio- and videomaster with one product masterlinked and the other with AUDIO AUX connection.
It is able to send audio and control signals in both directions in an AV setup. This is what you need, and yes, if properly configured the connected audio product and the converter will respond to video commands like TV.
Hope this helps
Stefan
Hi Stefan,
Thanks for you help and being a complete noob. By way of configuring what would I need to do to make it respond to the TV command?
James
1611 converter must detect your audiomaster on the Masterlink end. Connect the converter to your audiomaster with ML cable and then to the mains. This should make the converter configure to ML-audio and opening the AUX port when you select a video source (TV, DVD...). Your audio device must be able to respond to video sources. You have to set your BS to A.OPT 2 (this will make it responds to audio- AND video commands. Your link devices must be set to L.OPT 6 for the same reason. For option setting see manual or Beolink Handbook. For wiring of the AUX socket see beotech site here on Beoworld - you need Aux-in of the converter for your setup. To learn more about BL converters in a Masterlink setup see Lintronic site:
http://www.lintronic.dk/AppNote_BeoLink.pdf
Hope this helps
Stefan
