Sony TV - Audio output to masterlink
Hi all,
I previously had a Beovision 7, I've now replaced this with a Sony 4k TV (very nice). I have B&O in every other room, and a masterlink plug still behind the new TV. Is there a device I can use to take an audio output from Sony TV so I can listen to it in other rooms?
James
I think the Beolink TV Converter 1615 could close this gap
former known as smuehli
Ah, think looks promising! Thanks :)
The standard Beolink converter will work fine as long as you don't have another ML tv on the network.
Hi guys,
I've got this now and plugged in. Is tehre anyway to tell if its on at all? Not sure if it's working!
James
Do you have an IR-Eye connected to the converter or is the converter connected to an audio-master?
The Beolink converter should react to the "TV" command and open up its AUX-input.
Not really sure what you mean.
I have the beolink connected with a figure of 8 power cable, aux cable and masterlink. Do I need something else?
No, just press TV on your Beo4 or 1000 and you should hear the TV ...
If not, than you could/should change the option setting maybe. This should be explained in the manual of the converter.
Do you have a separate stereo-system (Beosound 3000, 9000, Beocenter 2, Beosound 4...) in your house? If yes, it works like smuehli and I told you: Just press TV on the remote.
But if there's NO other device you'll need an external Infrared receiver from B&O for the Beolink converter to contol it. Otherwise he simply doesn't know when to turn on or off. ;-)
Yep, I have a Beosound 3200 in the living room also, though nothing connected. It's just to power the A.AUX and radio for everything else.
I'm trying TV on any of my BeoLab 3500s through the house. If I press TV it turns on, then turns off after a couple seconds (assume this means it can't find it).
Any debugging suggestions? :)
