Sonos + Videomaster
Hi, has someone connected a Sonos ZP90 directly to a videomaster via S/PDIF only? If doing so, will I be able to send the sound to linkrooms via ML? If this also worls how do I trigger the Sonos input on the Videomster from lets say a Beolab 3500?
/Lars
Nope. You can connect directly to a videomaster, but you have to go RCA out. ML only carries analog signals. The BeoSystem 3 platform will mix down the digital stream from the HDMI, but I don't believe that it does so with SPDIF.
Thanks for the answer. I guess this means that it should be possible to use digital signals on the speakers connected to the videomaster but only analog for the ML distribution.
