Sonos port to Beolab 5 auto trigger on
I recently bought a Sonos Port. I connected the port to my Beolab 5 (digital coax and sync cable).
All works fine and I enjoy the Sonos Software and integration with Google home and Airplay.
One thing is missing; I need to switch on the BeoLab with my Beoremote one.
Not a big issue, but ideally I would to have them triggered by the Sonos Port, once it sends a signal / I trigger it with the Sonos app / Airplay2 / Google Home.
The Sonos port has a 12v trigger but I understand there is no cable available to leverage this with the Beolab 5.
Are there other solutions? Will this work?:
use a low voltage car type relay.
The sonos 12v activates the relay then making the contact for the 5v?? signal from a separate transformer for the power link?
When activated does the Sonos send out the 12v constantly?
With a couple of adapters from sounds heavenly this should be possible.
Thanks for suggesting my cables.  Unfortunately with Beolab 5 it is not possible to activate the speakers via a voltage trigger - a coded Datalink signal is needed (either via the Powerlink socket or IR remote control) in order to wake the speakers before use.
The simplest option is to use a Beo4 remote to turn the speakers on.
Kind regards, Steve.
thanks StUrrock and Steve for your suggestions and comments.
One other low-tech-high-tech solution I can think of is to bold this
Steve, isn't it time to develop a cable that can do this activation?
Using a USB charger as power supply and a PIC chip...?
Hi Dante,
That is a good idea....but first I need to borrow a pair of Beolab 5s for testing - anyone have a spare set that I can borrow please? 😁
Not sure this falls in the same category, but triggering upon play is one of my most desired features. I still have a BV5 and BV7. I’d love to bring them into AP2 multi-room via an APE. And then have it play audio-only without turning on the screen via some form of sensing? If there was a cable to achieve this, i’d be thrilled and would have a rather high willingness to pay.
Thanks,
That is good to know.  If there is enough interest, I will make a serious attempt to locate a pair of Beolab 5s with a view to designing an auto-trigger device.
that would be awesome and you can already sign me up ;-)
unfortunately I do not have a second pair of Beolab 5 standing around........... but if this needs to be tested I am happy to do so if that is helpful.
I am interested in getting this auto-trigger cable as well!
