After having done a lot of reading on these speakers and listening to them on two occasions, I have a few remaining questions that I would like to get out of the way before committing to buying a set.
The questions are:
Where is the IR receiver located, and how sensitive are they? Background of the question is I want to use a Logitech Harmony remote (found out this should work), and place a blaster under a floating cabinet which will beam into the room (though not directly onto both speakers). I anticipate to get a somewhat more recent set that has the sync ports.
When a demoed a set, they were hooked to a streamer using a digital cable. The volume was controlled via a Beo4. When changing the volume, only 1 speaker's LED flashed (the master), indicating a volume change, though it appeared both speakers actually changed volume. I don't think there was a sync cable connected. Is this normal?
Do people experience image/sound sync issues using a setup like: LG Oled TV (playing playstation and hd tv being external sources to the tv and internal sources like netflix), optically hooked up to a streamer (aim to use a Bluesound Node 2), which is subsequently digitally hooked to the Beolabs. This is a pure stereo setup and I have read most sync issues arise when there is some surround processing going on.
What cables were originally supplied with a new pair of Beolab 5s? I have located a set that has original packaging, would like to receive everything that should go with it.
I have read some posts on PIN codes being applicable to these speakers. What should I know about this? Should these be supplied with the speakers and when should I need them? I have no need to apply some sort of extra security measures on them.
Can I get these properly setup without a Beo4 at all, only using a Logitech Harmony?
I think that's it. Looking forward to your input and thanks in advance!
