I am considering to add some BLs to a non-B&O televisions. Initially, I was planning to do so with a Connection Hub, but am now thinking that a Beosound Core may be an even better solution to do so. Some questions for the experts on this forum:
1) Is the current Beosound Core already MK2 and/or any update expected?
2) Would be as straightforward to connect my non-B&O television to the Core and then to a pair of BL8000 (or BL3 or BL5 or BL18) as it is with the Connection Hub?
3) Can I connect the Essence wheelie to start & pause audio from the Core? What about volume control (does this interfere with the volume control from the TV)
4) Assuming I play airplay-2 to the BL via the Core. Can I pause this stream for this speaker (speakers in other rooms keep playing) and then rejoin again by clicking play (on wheelie)
5) Could I connect a vinyl player to the Core? Would I still need a pre-amp?
6) How can I switch between audio sources? For example: let's assume I watch television (audio on BL via Core) and I cast airplay-2 to the Core. Would this stop the audio from TV and start the airplay stream? What happens if I pause the airplay stream, does the TV stream commences again?
Thanks for all your help!
