some questions about beosound 9000
My Beosound 900 is connected to Beovision 10 using Masterlink cable. But I can not use remote of beo 4 to play beosound 9000.
when do it manually , my system works well. after that, I could use remote to control system with funtions such as select CD 2,3,4,5,6 or turn off system. However, I still do not use remote of beo 4 to play beosoud 900.
So is this configuration problem?
What speakers do you have connected to the Beosound 9000?
If you are only using the BV10 for speakers then the Beosound 9000 will default to Option 0, no remote control.
To make the remote work, you must either connect speakers to the powerlink socket in the 9000 or obtain a dummy plug from steve@soundsheavenly.co.uk
how to disable power saving mode on beovision 10 ?
