[SOLVED] MCL 2AV (2031) S.W. 2.1 programming
Dear colleagues,
I have MCL 2AV (2031) SW2.1 and IR Transciever (2047) SW2.0
I would like to connect it to my beomaster 5500 to get extra audio inputs.
Please help me with programming MCL 2AV.
Many thanks in advance,
Aleksei
Hi Vienna,
Thanks for your replay.
I think if I connect MCL 2AV PoweLink signal outputs pins with BM5500 AUX input pins it will work for me. At the moment I have connected with same mode my Beosystem AV 7000 and Beomaster 5500 and it works well as extended inputs.
My main problem, that I can't find programming guide for MCL 2AV. As soon I'm not a first owner of MCL 2AV, I don't know in which mode it will worked.
Best regards,
Hi Ralph-Marcus,
Thank you for solution. This is exactly, what I wanted.
Volume control not a problem for me, because I can bypas the volume control IC's TC9177P.
Many thanks for assistance,
Aleksei
Or put the ML2AV in Option 4 and use the LINK-command to select other sources and do the volumecontrol from the ML2AV. No bypasses needed that way.
