Dear colleagues,
I have MCL 2AV (2031) SW2.1 and IR Transciever (2047) SW2.0
I would like to connect it to my beomaster 5500 to get extra audio inputs.
Please help me with programming MCL 2AV.
Many thanks in advance,
Aleksei
[SOLVED] MCL 2AV (2031) S.W. 2.1 programming
Hi Vienna,
Thanks for your replay.
I think if I connect MCL 2AV PoweLink signal outputs pins with BM5500 AUX input pins it will work for me. At the moment I have connected with same mode my Beosystem AV 7000 and Beomaster 5500 and it works well as extended inputs.
My main problem, that I can't find programming guide for MCL 2AV. As soon I'm not a first owner of MCL 2AV, I don't know in which mode it will worked.
Best regards,
Hi Ralph-Marcus,
Thank you for solution. This is exactly, what I wanted.
Volume control not a problem for me, because I can bypas the volume control IC's TC9177P.
Many thanks for assistance,
Aleksei
Or put the ML2AV in Option 4 and use the LINK-command to select other sources and do the volumecontrol from the ML2AV. No bypasses needed that way.Volume control not a problem for me, because I can bypas the volume control IC's TC9177P.
