Software Update Beolab 90
There is a new software release (3.1.0)
Has anyone tried downloading this?
And is there a place they post releas notes?
My BeoApp suggests 3.1.0.1075 as the latest software. This has been so as far back as early October?
The software build date is def 08/10/21 so your probably seeing a roll-out of software based on some B&O determined plan.
I dont see any other update notes. I suspect it may be to do with the revision of the BeoApp?
10
Works fine on the 50’s here, same software.
It's an improvment over the last one.
Finally there’s a update. Had some strange bugs at the 90’s and 50’s in store and at some clients.. fixed now ! 😁
