Software for Beo5 remote.
Hi.
I just bought a Beo 5 remote.
Is this the right cable to program the remote? link
Does anyone know where to get the software for programing the remote?
Regards
Magnus
magnusl81@msn.com
No need to buy it online.
Just go to your PC dealer and get a USB to micro USB cable.
Take the remote control holder to the shop so you can show them the socket, they'll find the right cable for you.
p.
There is a search function on this site...
But try to look here:
The cable required is a standard USB to reduced USB plug as shown below
Thanks a lot for all the help!!
(I used the search function but somehow i missed that one) ❓
/Magnus
Has Beo quit supplying us with the usb cable? I got mine with my Beo5...
As long as you have the desk charger!
The wall charger does not have the ability to connect Beo5 to a computer, as I found out the hard way!
